Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Disassembling the Nokia 6300 is not very hard and if you know how to disassemble other Nokia phones this will be very easy. You need a Torx T6 screwdriver.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Take off the back cover by pushing it down and sliding it backwards.
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Take out the battery, SIM card, and MicroSD card. Unscrew the two T6 Torx screws.
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Manta Precision Bit Set
    112 Bits für jede Reparatur.
    Upgrade Your Toolbox
  4. Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  5. You can take off the keypad now, this is sitting loose on top of the sensors.
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  6. The motherboard with it's screen are now loose, you can pop it right out.
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  7. There's your phone! There's your phone! There's your phone!
    • There's your phone!
Abschluss
19 weitere Nutzer haben diese Anleitung absolviert.
LucasJV
717 Reputation
3 Anleitungen geschrieben
Verheij.co Mitglied von Verheij.co
Business
1 Mitglied
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 32
Insgesamt: 21,464
