Einleitung
Opening of the mixer body to replace the damaged coupler (small black plastic part between the motor and the foot)
Was du brauchst
Remove the screw with the star pattern on the mixer body.
Insert a flat screwdriver at the bottom of the mixer (circled on the picture)
Remove the motor from the device.
The coupler is simply fitted onto the motor shaft, it can be removed by prying it up with the screwdriver for example.
The foot of the mixer needs to be replaced completely (spare part available on the SEB website for example)
To reassemble your device, follow the instructions in reverse order.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
