Zum Hauptinhalt wechseln
Samsung SPEX SCH-R210 Back Cover Replacement
  1. Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 3 Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: Schritt 1, Bild 2 von 3 Samsung SPEX SCH-R210 Back Cover Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Lay the phone on its front side so the back is visible.
    • Use your thumb to gently and firmly press down on the triangle arrow found on the cover of the phone.
    • Press down on the arrow until you hear a popping sound, which will remove the cover of the phone.
    • Slide the cover down from the phone to remove it. Set the cover aside.
Abschluss
Austin
201 Reputation
2 Anleitungen geschrieben
WRI115, Team 1-4, Ruszkiewicz Spring 2013 Mitglied von WRI115, Team 1-4, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G4
3 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
uh, this is so easy that I’m pretty sure it doesn’t need a guide for it. I found an old Spex (perfect condition except for a few flaws) and I knew how to take off the cover from day 1, but it’s nice you made this anyway. Thx ig
Isaac Kassahun - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 180
