Zum Hauptinhalt wechseln
Disconnecting the Battery
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Disconnecting the Battery, Bottom Cover: Schritt 1, Bild 1 von 2 Disconnecting the Battery, Bottom Cover: Schritt 1, Bild 2 von 2
    • Turn the laptop off, and disconnect the power cable.
    • Flip the laptop upside down.
    • Remove the eleven 6.6 mm Phillips #0 screws from the bottom cover.
  2. Disconnecting the Battery: Schritt 2, Bild 1 von 3 Disconnecting the Battery: Schritt 2, Bild 2 von 3 Disconnecting the Battery: Schritt 2, Bild 3 von 3
    • Insert a plastic opening tool into a gap between the case and the bottom cover.
    • Insert blue plastic picks into the gap between the case and the bottom cover, working around the seam.
    • The bottom cover is now loose. Pull it upwards, away from the laptop, and set it aside.
  3. Disconnecting the Battery, Disconnecting the Battery: Schritt 3, Bild 1 von 3 Disconnecting the Battery, Disconnecting the Battery: Schritt 3, Bild 2 von 3 Disconnecting the Battery, Disconnecting the Battery: Schritt 3, Bild 3 von 3
    • Use a plastic spudger to loosen the black tape around the large battery connector on the motherboard.
    • Once loosened, pull back on the tape to remove it from the connector.
    • Use a plastic spudger to pull the battery connector away from the motherboard.
    • Leave the battery unplugged for the following steps.
  4. Disconnecting the Battery: Schritt 4, Bild 1 von 2 Disconnecting the Battery: Schritt 4, Bild 2 von 2
    • Press and hold the laptop's power button for about five seconds to discharge any remaining power in the system.
    • Do not touch any exposed components while carrying out this step or put them in contact with conductive materials.
    • Leave the battery connector unplugged and out of the way for the rest of the time the laptop is open.
Abschluss
Henry Bryant
325 Reputation
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 74
