Zum Hauptinhalt wechseln
Dismountable Hand Blender
Was du brauchst
  1. Dismountable Hand Blender, Dismountable Hand Blender: Schritt 1, Bild 1 von 1
    • Finding and fixing the problem is a cinch!
    • Disassembling the mixer is very destructive!
    • This appliance is a clear example of planned obsolescence since a worn (carbon) brush makes it fit for the trash.
    • If the fault is in the electronic module, clever cutting can make an acceptable repair possible as shown in this ElectroMax video.
  2. Dismountable Hand Blender: Schritt 2, Bild 1 von 3 Dismountable Hand Blender: Schritt 2, Bild 2 von 3 Dismountable Hand Blender: Schritt 2, Bild 3 von 3
    • The speed control knob is easy to disassemble by inserting a knife blade under the graduated circle and prying it up.
    • There are three obstacles to the removal of the motor and electronics module from this mixer:
    • The entire motor block enclosure is firmly secured with adhesive.
    • This motor bearing fastener acts as a circular mount.
    • This plunger system fastener is a second circular mount.
    • I do not see a way around any of these three issues without a certain amount of "destruction".
  3. Dismountable Hand Blender: Schritt 3, Bild 1 von 1
    • One of the two leads has broken off. Possibly made fragile by improper assembly?
    • Correctly resoldering the lead lets the motor operate normally again.
Abschluss
We do need to cut the shell off the mixer, which makes salvaging this part difficult.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
fr en
100%
Hier starten ›
Louis Possoz
435 Reputation
3 Anleitungen geschrieben
Repair Café Louvain-la-Neuve Mitglied von Repair Café Louvain-la-Neuve
Community
2 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
pourquoi acheter du matériel pro si on ne peut pas le réparer
laurencedelanoue - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 70
Letzte 30 Tage: 251
Insgesamt: 12,969
