Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Disconnect the antenna cable.
    • Close the display.
    • Turn the computer upside down with the back of the computer facing you.
  1. From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
    • From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  2. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  3. From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D." From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  4. Turn the computer right-side up and open the display.
    • Turn the computer right-side up and open the display.
    • Carefully remove the antenna cable and the display cables from their routing guides.
  5. NOTICE: Be careful not to damage the display switch when removing the display.
    • NOTICE: Be careful not to damage the display switch when removing the display.
    • Lift the display assembly out of the computer base.
Abschluss
Terrence15
70.583 Reputation
442 Anleitungen geschrieben
Informative Technologies Inc. Mitglied von Informative Technologies Inc.
Community
15 Mitglieder
925 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 46
