Einleitung
NOTE: This guide is used for training purposes only. Do not use this guide for repair. For the official guide, follow this link.
Prerequisite-only guide for detaching the display assembly for access to the iPhone 11 internals.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
To access the screws in the following step, tilt the display by slightly lifting its lower edge.
Use a Y000 driver to remove the three 1.1 mm-long screws securing the battery connector bracket.
Use a spudger or a clean fingernail to pry the battery connector up from its socket on the logic board.
Bend the connector slightly away from the logic board to prevent it from accidentally contacting the socket.
Use a Y000 driver to remove the six 1.1 mm screws securing the logic board cover bracket.
Use a spudger or a fingernail to disconnect the LCD panel cable connector.
Disconnect the digitizer connector next to it.
Use the point of a spudger or a fingernail to disconnect the front panel sensor assembly connector.
Remove the display assembly.
During reassembly, pause here if you wish to replace the waterproof adhesive around the edges of the display.
