Zum Hauptinhalt wechseln
Door Hinge Replacement
Was du brauchst
  1. Door Hinge Replacement, Hinge: Schritt 1, Bild 1 von 2 Door Hinge Replacement, Hinge: Schritt 1, Bild 2 von 2
    • Take measurements of the door hinge using a tape measure and use the measurements to find a replacement door hinge.
  2. Door Hinge Replacement: Schritt 2, Bild 1 von 2 Door Hinge Replacement: Schritt 2, Bild 2 von 2
    • Use two sturdy pieces of wood or cardboard that can keep the door in place and put them underneath the door.
    • Make sure that the door isn’t slanted or tilted to make it easier to replace the new door hinge.
  3. Door Hinge Replacement: Schritt 3, Bild 1 von 2 Door Hinge Replacement: Schritt 3, Bild 2 von 2
    • Remove the three screws from the hinge that are connected to the door by using a Phillips 1 screwdriver.
    • Remove the three screws from the hinge that are connected to the door frame using a Phillips #1 screwdriver.
  4. Door Hinge Replacement: Schritt 4, Bild 1 von 2 Door Hinge Replacement: Schritt 4, Bild 2 von 2
    • Repeat Step 3 with the bottom hinge on the door.
  5. Door Hinge Replacement: Schritt 5, Bild 1 von 2 Door Hinge Replacement: Schritt 5, Bild 2 von 2
    • Rub sandpaper on the areas where the new hinges will be.
    • This makes sure that splinters or any wood debris from both the frame and the door will be removed.
  6. Door Hinge Replacement: Schritt 6, Bild 1 von 2 Door Hinge Replacement: Schritt 6, Bild 2 von 2
    • When replacing your new door hinge, make sure that the hinge that is facing towards you can be fully closed
  7. Door Hinge Replacement: Schritt 7, Bild 1 von 3 Door Hinge Replacement: Schritt 7, Bild 2 von 3 Door Hinge Replacement: Schritt 7, Bild 3 von 3
    • Align the new door hinge with the screw holes in the frame and screw in the new door hinge in the frame.
    • Repeat this with the bottom area of the door.
  8. Door Hinge Replacement: Schritt 8, Bild 1 von 3 Door Hinge Replacement: Schritt 8, Bild 2 von 3 Door Hinge Replacement: Schritt 8, Bild 3 von 3
    • Align the new door hinge with the screw holes in the door and screw in the new door hinge.
  9. Door Hinge Replacement: Schritt 9, Bild 1 von 2 Door Hinge Replacement: Schritt 9, Bild 2 von 2
    • Spray a small amount of WD-40 at the back top and bottom hinge and wipe it down with an old rag.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Zeniff Aviles
234 Reputation
1 Anleitung geschrieben
York University, Team S1-G31, Woodhouse Winter 2021 Mitglied von York University, Team S1-G31, Woodhouse Winter 2021
YORK-WOODHOUSE-W21S1G31
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 36
Insgesamt: 643
