Zum Hauptinhalt wechseln
Door Stop Replacement
Was du brauchst
  1. Door Stop Replacement, Door Stop: Schritt 1, Bild 1 von 3 Door Stop Replacement, Door Stop: Schritt 1, Bild 2 von 3 Door Stop Replacement, Door Stop: Schritt 1, Bild 3 von 3
    • Twist the anchor fitting of the old door stop in counter clockwise direction.
    • Remove the anchor fitting from the mount.
    • Anchor fitting: is a part of the door stop circled in red.
  2. Door Stop Replacement: Schritt 2, Bild 1 von 3 Door Stop Replacement: Schritt 2, Bild 2 von 3 Door Stop Replacement: Schritt 2, Bild 3 von 3
    • Use a drill (or a screwdriver) to remove the two screws from the mount base.
    • After you remove the mount base, use the hammer to reposition these two screws.
  3. Door Stop Replacement: Schritt 3, Bild 1 von 2 Door Stop Replacement: Schritt 3, Bild 2 von 2
    • Use a screwdriver to remove the mount base out of the new anchor fitting by spinning the screwdriver counter-clockwise.
  4. Door Stop Replacement: Schritt 4, Bild 1 von 3 Door Stop Replacement: Schritt 4, Bild 2 von 3 Door Stop Replacement: Schritt 4, Bild 3 von 3
    • Using a screwdriver or a drill, attach the new mount base to the wall with the two screws.
  5. Door Stop Replacement: Schritt 5, Bild 1 von 3 Door Stop Replacement: Schritt 5, Bild 2 von 3 Door Stop Replacement: Schritt 5, Bild 3 von 3
    • Attach the anchor fitting into the mount base by rotating it clockwise.
  6. Door Stop Replacement: Schritt 6, Bild 1 von 2 Door Stop Replacement: Schritt 6, Bild 2 von 2
    • Remove the old door fitting by rotating it counter-clockwise.
  7. Door Stop Replacement: Schritt 7, Bild 1 von 3 Door Stop Replacement: Schritt 7, Bild 2 von 3 Door Stop Replacement: Schritt 7, Bild 3 von 3
    • Use the drill to remove the two screws out of the threaded insert.
    • Clean the screws holes (if necessary) before putting a new screw in.
  8. Door Stop Replacement: Schritt 8, Bild 1 von 3 Door Stop Replacement: Schritt 8, Bild 2 von 3 Door Stop Replacement: Schritt 8, Bild 3 von 3
    • Insert a screwdriver into the bottom hole of the threaded insert and rotate it counter-clockwise to remove the threaded insert.
  9. Door Stop Replacement: Schritt 9, Bild 1 von 2 Door Stop Replacement: Schritt 9, Bild 2 von 2
    • Place the threaded insert onto the door.
    • Using a screwdriver or a drill, attach the threaded insert to the door with two screws.
  10. Door Stop Replacement: Schritt 10, Bild 1 von 3 Door Stop Replacement: Schritt 10, Bild 2 von 3 Door Stop Replacement: Schritt 10, Bild 3 von 3
    • Assemble the rest of the door stop in the following order:
    • Spring.
    • Rectangular compartment.
    • Door stop button.
    • Outer shell.
    • Place the door stopper onto the threaded insert and and attach it by rotating it clockwise.
Abschluss
Khoa Bui
198 Reputation
1 Anleitung geschrieben
York University, Team S1-G111, Woodhouse Fall 2020 Mitglied von York University, Team S1-G111, Woodhouse Fall 2020
YORK-WOODHOUSE-F20S1G111
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 49
Insgesamt: 3,705
