Einleitung
If your door weather strip is damaged and needs replacement, this guide is for you. Door weather strips are an essential addition to your door to keep the elements out and help save money on your energy bill. Weather strips work on sealing your door and not letting the outside temperature affect your home. No need to hassle your landlord or get expert help to fix it.
You will need to acquire a similar door strip to the one damaged. After acquiring it, you can remove the old one using a hammer or drill depending on nail type used. Older models use nails while new models will have screw nails to install. An aluminum/vinyl 3/4 in. x 7 ft. door strip is used in the guide. The hardest part is placing the door strip in a location where it will not stop the door from closing and be able to seal the door after it closes. A marker will be used to get the right placement for the door strip.
Was du brauchst
To remove the damaged door strip, use one finger of the claw on hammer to loosen nails first.
Adjust the new weather strip to the door height using a cutting plier. Use measuring tape to get the accurate length.
Close the door and lay the door strip on the wall to figure the placement of the door strip. Mark the end of door for induction.
To start installing the weather strip, add the screw nails to the holes on the weather strip.
Test that your door weather strip securely seals your door. Make sure you can lock the door.
Close the door to test if there are any gaps between the door and weather strip. Make the weather securely seals the door.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
