Zum Hauptinhalt wechseln
Doov v15 Sim Card Replacement
Was du brauchst
  1. Doov v15 Sim Card Replacement, Sim Card: Schritt 1, Bild 1 von 1
    • Use the Jimmy to crack open the phone's back cover. Slide it under an edge of the phones back cover and carefully loosen the edge. The casing should pop open slightly.
  2. Doov v15 Sim Card Replacement: Schritt 2, Bild 1 von 2 Doov v15 Sim Card Replacement: Schritt 2, Bild 2 von 2
    • Use an Ifixit opening tool and slide it around the phones back cover. The Sim Card will be visible above the battery to the right.
  3. Doov v15 Sim Card Replacement: Schritt 3, Bild 1 von 2 Doov v15 Sim Card Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the battery: Once the back casing is removed, the battery will be visible. Use the ifixit opening tool to remove the battery. Place the ifixit opening tool at the top of the battery and pull it back, or simply use your hand to remove it.
  4. Doov v15 Sim Card Replacement: Schritt 4, Bild 1 von 2 Doov v15 Sim Card Replacement: Schritt 4, Bild 2 von 2
    • Use the Ifixit opening tool and place it in the hole above the SIM card slot and push it downwards, so the SIM card slides downward. Place the iFixit opening tool on the now more visible SIM card and slide it down for an easy removal.
  5. Doov v15 Sim Card Replacement: Schritt 5, Bild 1 von 2 Doov v15 Sim Card Replacement: Schritt 5, Bild 2 von 2
    • Place the new SIM card in the slot by sliding it back in the slot, as shown in the figure (facing the sim number and code upward.)
Abschluss
Imani Williams
121 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 65
