Einleitung
Purchasing a new or used front-facing camera will be necessary.
Was du brauchst
The rear panel is secured to the front case and can simply be pried apart without damage.
Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
Use the flat end of a spudger to disconnect the front-facing camera cable from its socket on the motherboard.
Simply, pull back the tape and remove the camera.
Eine weitere Person hat diese Anleitung absolviert.
