Zum Hauptinhalt wechseln
Dopo Double Power 7 Motherboard Replacement
Was du brauchst
  1. Dopo Double Power 7 Motherboard Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Remove any static tape covering the motherboard.
  6. Dopo Double Power 7 Motherboard Replacement: Schritt 6, Bild 1 von 2 Dopo Double Power 7 Motherboard Replacement: Schritt 6, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
    • The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
    • Once the lever is lifted, pull out the cable by gently tugging on it.
  7. Dopo Double Power 7 Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
  8. Dopo Double Power 7 Motherboard Replacement: Schritt 8, Bild 1 von 2 Dopo Double Power 7 Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Using wire cutters, cut the red, black, and grays wires.
    • The motherboard can now be removed
    • Leave enough wire to be re-soldered back if possible.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
mike pelosi
682 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 1-2, Miles Fall 2015 Mitglied von UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 493
