Zum Hauptinhalt wechseln
Dopo Double Power 7 Speaker Replacement
Was du brauchst
  1. Dopo Double Power 7 Speaker Replacement, Rear Panel: Schritt 1, Bild 1 von 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
  2. Dopo Double Power 7 Speaker Replacement: Schritt 2, Bild 1 von 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
  3. Dopo Double Power 7 Speaker Replacement: Schritt 3, Bild 1 von 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
  4. Dopo Double Power 7 Speaker Replacement: Schritt 4, Bild 1 von 1
    • The rear panel should come completely off.
  5. Dopo Double Power 7 Speaker Replacement, Speaker: Schritt 5, Bild 1 von 1
    • Using wire cutters, cut the red and black wires connected to the speaker.
    • The speaker is magnetized and not permanently attached.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
mike pelosi
682 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 1-2, Miles Fall 2015 Mitglied von UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 189
