Einleitung
This guide walks through the process to replace the back speakers on the device. For safety reasons, you must first disconnect the battery from the device. After the battery is removed, you can follow the rest of the directions to replace the speakers safely.
Was du brauchst
Insert the plastic opening tool between the white back cover and black front over.
Slide the plastic opening tool along the edgeof the device until back cover is detached and remove the cover.
Remove the yellow tape holding the battery to the device using your fingers or plastic opening tool if necessary.
In diesem Schritt verwendetes Werkzeug:Plastic Cards$2.99
Insert the plastic card under the battery and use it to remove the battery from the device.
Desolder the red and black wires connecting the battery to the motherboard and remove the battery.
Desolder the red and black wires connecting each speaker to the motherboard.
