Zum Hauptinhalt wechseln
Dragon Touch MID 7138 Motherboard Replacement
Was du brauchst
  1. Dragon Touch MID 7138 Motherboard Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Wedge a plastic spudger between the back panel and the screen to begin lifting the back cover.
    • Wedge around all edges until the back cover pops off entirely.
  2. Dragon Touch MID 7138 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Gently pry the back cover from the screen using your hands.
  3. Dragon Touch MID 7138 Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: Schritt 3, Bild 2 von 3 Dragon Touch MID 7138 Motherboard Replacement, Motherboard: Schritt 3, Bild 3 von 3
    • Remove tape covering wire joints
    • Remove (3) 2.5mm screws using a PH001 screw driver.
    • The screws locations are highlighted in the image to the left.
  4. Dragon Touch MID 7138 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove black tape and using your fingers, pull the orange ribbon labeled BSR028-V3-KDX out of its port.
  5. Dragon Touch MID 7138 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Similar to previous step, pull the large U2 ribbon gentle out of its port.
  6. Dragon Touch MID 7138 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the last orange ribbon labeled 24 by pulling the motherboard away from the ribbon
  7. Dragon Touch MID 7138 Motherboard Replacement: Schritt 7, Bild 1 von 2 Dragon Touch MID 7138 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Desolder the wires attached to the mother board with a soldering iron.
    • Then pull the wires from the joints.
Abschluss
Trevor Farkas
101 Reputation
1 Anleitung geschrieben
IUPUI, Team 2-4, Baechle Spring 2017 Mitglied von IUPUI, Team 2-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G4
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 567
