Zum Hauptinhalt wechseln
Drawstring Bag Tab Replacement
Was du brauchst
  1. Drawstring Bag Tab Replacement, Drawstring Bag Tab: Schritt 1, Bild 1 von 3 Drawstring Bag Tab Replacement, Drawstring Bag Tab: Schritt 1, Bild 2 von 3 Drawstring Bag Tab Replacement, Drawstring Bag Tab: Schritt 1, Bild 3 von 3
    • Using your pen and ruler, draw two strips of 3.5" x 0.5" pieces of cloth.
    • Cut those two strips with your scissors.
  2. Drawstring Bag Tab Replacement: Schritt 2, Bild 1 von 1
    • Align your two strips back to back.
    • Use two sewing pins to hold the strips in place for easy alignment during the sewing process.
    • Carefully handle the pins to avoid accidental punctures or injury. Use a thimble if needed.
  3. Drawstring Bag Tab Replacement: Schritt 3, Bild 1 von 3 Drawstring Bag Tab Replacement: Schritt 3, Bild 2 von 3 Drawstring Bag Tab Replacement: Schritt 3, Bild 3 von 3
    • Using your thread and sewing needle, sew along the long edge in a straight line using a straight stitch.
    • Use a seam allowance of 1/8"
    • Repeat on the other side.
    • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if neede.
  4. Drawstring Bag Tab Replacement: Schritt 4, Bild 1 von 2 Drawstring Bag Tab Replacement: Schritt 4, Bild 2 von 2
    • Fold your strip around the cord to your drawstring bag to create a loop.
  5. Drawstring Bag Tab Replacement: Schritt 5, Bild 1 von 3 Drawstring Bag Tab Replacement: Schritt 5, Bild 2 von 3 Drawstring Bag Tab Replacement: Schritt 5, Bild 3 von 3
    • Using the whipstitch technique, sew the two ends together.
    • Carefully handle the needle to avoid accidental punctures or injury. Use a thimble if needed.
  6. Drawstring Bag Tab Replacement: Schritt 6, Bild 1 von 3 Drawstring Bag Tab Replacement: Schritt 6, Bild 2 von 3 Drawstring Bag Tab Replacement: Schritt 6, Bild 3 von 3
    • Take the sewn ends and insert them 1/4" into the ripped hole where the original tab was.
  7. Drawstring Bag Tab Replacement: Schritt 7, Bild 1 von 3 Drawstring Bag Tab Replacement: Schritt 7, Bild 2 von 3 Drawstring Bag Tab Replacement: Schritt 7, Bild 3 von 3
    • Align the fabric with the seam line.
    • Using the whipstitch technique, sew it to the bag from the outside ensuring the stitches are along the seam.
  8. Drawstring Bag Tab Replacement: Schritt 8, Bild 1 von 2 Drawstring Bag Tab Replacement: Schritt 8, Bild 2 von 2
    • Now you have a working drawstring bag!
Ziellinie
Ava Overton
157 Reputation
1 Anleitung geschrieben
UC Davis, Team 3-1, Andersen Winter 2025 Mitglied von UC Davis, Team 3-1, Andersen Winter 2025
UCD-ANDERSEN-W25S3G1
3 Mitglieder
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 64
Insgesamt: 478
