Zum Hauptinhalt wechseln
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place the shade and bottom bar on a flat surface. To require less space, roll the shade so only the bottom bar is showing.
    • Place the shade and bottom bar on a flat surface. To require less space, roll the shade so only the bottom bar is showing.
  2. Add a drop of super glue directly to the double-stick tape. Hold the shade material on the applied glue. The glue should dry in 10-20 seconds. Repeat this process in any area on the bottom bar that comes unstuck.
    • Add a drop of super glue directly to the double-stick tape.
    • Hold the shade material on the applied glue. The glue should dry in 10-20 seconds.
    • Repeat this process in any area on the bottom bar that comes unstuck.
Abschluss
David
709 Reputation
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 66
