Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the four Phillips head screws that fasten the motor hub to the tube adapter. Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
    • Remove the four Phillips head screws that fasten the motor hub to the tube adapter.
  2. Using a flathead screwdriver, pry the bearing cap from the tube. Using a flathead screwdriver, pry the bearing cap from the tube.
    • Using a flathead screwdriver, pry the bearing cap from the tube.
  3. Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
    • Move the hub to the edge of the shaft so it is flush, and tighten the set screw using a T5 screwdriver bit.
    • The hub should fit snugly on the shaft, unable to rotate freely.
    • Optional- Add a drop of thread locking liquid to permanently hold the set screw in place after tightening.
Abschluss
David
709 Reputation
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 89
