Zum Hauptinhalt wechseln
Einleitung
This is a prerequisite guide only. In the following steps, you will remove two exterior parts, then remove the screws that hold the casing together.
  1. Start by removing the housing cap by unscrewing it. Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • Start by removing the housing cap by unscrewing it.
    • Next, unscrew the now exposed collet nut while holding down the shaft lock button.
    • To remove the collet nut, you may need to use the small open-end wrench provided with the Dremel.
  2. Using your hands, carefully remove hanger from casing.
    • Using your hands, carefully remove hanger from casing.
  3. Remove the brush caps (one on each side) by using a flathead screwdriver bit. The brush caps are spring loaded.
    • Remove the brush caps (one on each side) by using a flathead screwdriver bit.
    • The brush caps are spring loaded.
  4. Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
    • Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
  5. Use a plastic opening tool to gently wedge apart the hard plastic threads.
    • Use a plastic opening tool to gently wedge apart the hard plastic threads.
  6. Use your hands to carefully remove the back casing so that none of the components fall out.
    • Use your hands to carefully remove the back casing so that none of the components fall out.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
John Cobb
1.452 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 15-4, Remmell Spring 2016 Mitglied von USF Tampa, Team 15-4, Remmell Spring 2016
USFT-REMMELL-S16S15G4
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 2
Insgesamt: 1,302
