Zum Hauptinhalt wechseln
Dremel 7300 MiniMite Cordless Collet Replacement
Was du brauchst
  1. Dremel 7300 MiniMite Cordless Collet Replacement, Collet: Schritt 1, Bild 1 von 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: Schritt 1, Bild 2 von 3 Dremel 7300 MiniMite Cordless Collet Replacement, Collet: Schritt 1, Bild 3 von 3
    • The device comes with a small black wrench to tighten the collet nut, during reassembly or changing the bits.
    • Press the blue button and hold it down.
    • Unscrew the collet nut, with your fingers (as if you were going to change the bit).
    • Continue until the collet nut comes completely off of the Dremel.
  2. Dremel 7300 MiniMite Cordless Collet Replacement: Schritt 2, Bild 1 von 3 Dremel 7300 MiniMite Cordless Collet Replacement: Schritt 2, Bild 2 von 3 Dremel 7300 MiniMite Cordless Collet Replacement: Schritt 2, Bild 3 von 3
    • Once the collet nut is off, you can remove the collet. It is the silver part that grips the bit when the collet nut tightens on it.
    • The collet itself may be in the shaft, or come off with the nut.
Abschluss
7 weitere Nutzer:innen haben diese Anleitung absolviert.
Kat
840 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 3-4, Sullivan Spring 2016 Mitglied von USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Too anyone having trouble unscrewing the collet, you may want to clamp vice grips on if its stuck tight. Worked for me.
Will - Antwort
I easily removed the bit by holding the blue button and using the black wrench to loosen it and then I remove the silver piece that holds the bit then when I tried to use another one of the attachments it seems like it’s too large to fit in there I haven’t been able to use any of the other attachments like polishing and the finer little grinders
Kate Denkers - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 32,531
