Zum Hauptinhalt wechseln
Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement
Was du brauchst
  1. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: Schritt 1, Bild 1 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: Schritt 1, Bild 2 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Battery: Schritt 1, Bild 3 von 3
    • Pull back on the release tabs to disconnect the battery pack from the housing.
    • When installing a new battery, you may need to charge it before using it.
  2. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: Schritt 2, Bild 1 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: Schritt 2, Bild 2 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement, Motor-Shaft Assembly: Schritt 2, Bild 3 von 3
    • Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
    • Make sure you have removed the battery before proceeding as accidentally powering-on the device while disassembling is dangerous due to the high-speed components inside.
  3. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: Schritt 3, Bild 1 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: Schritt 3, Bild 2 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: Schritt 3, Bild 3 von 3
    • Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
    • Gently lift the cover. It won't take much force to remove it.
  4. Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: Schritt 4, Bild 1 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: Schritt 4, Bild 2 von 3 Dremel 7300 MiniMite Cordless Motor-Shaft Assembly Replacement: Schritt 4, Bild 3 von 3
    • Lift the tip of the motor-shaft assembly gently, then pull the assembly out.
    • The blue battery contact and the spring for the shaft lock button may pop out when you remove the motor-shaft assembly. Make sure to keep track of these pieces, as they are very small.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 3-4, Sullivan Spring 2016 Mitglied von USF Tampa, Team 3-4, Sullivan Spring 2016
USFT-SULLIVAN-S16S3G4
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 3,106
