Zum Hauptinhalt wechseln
Dremel 8200 Disassembly
Was du brauchst
  1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: Schritt 1, Bild 1 von 2 Dremel 8200 Disassembly, Dremel 8200 Disassembly: Schritt 1, Bild 2 von 2
    • Take off the screw cap at the top
  2. Dremel 8200 Disassembly: Schritt 2, Bild 1 von 2 Dremel 8200 Disassembly: Schritt 2, Bild 2 von 2
    • Take out the battery
    • Remove oblong belt clip
  3. Dremel 8200 Disassembly: Schritt 4, Bild 1 von 1
    • Unscrew screws
    • Take back u clip out carefully
    • Be very careful to not injure yourself
  4. Dremel 8200 Disassembly: Schritt 6, Bild 1 von 2 Dremel 8200 Disassembly: Schritt 6, Bild 2 von 2
    • The casing should just open right up and be easily accessible
  5. Dremel 8200 Disassembly: Schritt 7, Bild 1 von 1
    • You can remove the buttons except for the sliding one that adjusts the speed
  6. Dremel 8200 Disassembly: Schritt 8, Bild 1 von 2 Dremel 8200 Disassembly: Schritt 8, Bild 2 von 2
    • You can take the motor out first and it will be a little hard to do so
    • Work your way down and take out each successive circuit board
    • The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
m. D. w. - Antwort
How do you replace just the bearing in this assembly?
Andre Da Silva - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 33
Insgesamt: 3,498
