Einleitung
This guide will show you how to replace a defective motor. With a few steps and a some tools, you will be able to open up the device and gain access to the motor. The motor can then be easily swapped out for a new one so that it can start working again.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
Remove the ring located around the speed selector switch by pulling apart on either side. (This should require very minimal force.)
Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a spudger.
Remove broken motor. Lift out the motor until you can see the wires that connect to it.
Remove the clips where the wires connect with the motor. This can be done with your fingers of a pair of tweezers.
3 weitere Nutzer haben diese Anleitung absolviert.
