Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show you how to open up your device. You will then have access to all the internal components. The power switch can then be replaced with minimal effort
Ersatzteile
Keine Ersatzteile angegeben.
  1. Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
  2. Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
    • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
  3. Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
  4. Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
  5. Remove five T9 Torx screws from the side of the tool. Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one. Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
    • Remove five T9 Torx screws from the side of the tool.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
  6. Remove the faulty power switch. It should come out of the device without using any force.
    • Remove the faulty power switch. It should come out of the device without using any force.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Shailing Santiago
346 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 Mitglied von UMass Dartmouth, Team 2-8, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G8
3 Mitglieder
5 Anleitungen geschrieben
Awesome!! Thanks!
christooher t - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 7
Letzten 30 Tage: 22
Insgesamt: 870
