Einleitung
This guide will show how to replace damaged casing on the Dremel MultiPro 395.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver. Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
    • Remove the blue caps located on either side of the MultiPro, using a 3 mm flathead screwdriver.
  2. Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands. Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out. Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
    • Pull one side of the hanger up and then pull away from the Multipro until the other side can be pulled out.
  4. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  5. Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver. Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver. Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
    • Remove the 4 screws located on the bottom of the Multipro with a T15 screwdriver.
  6. Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise. Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise. Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
    • Hold down the collet lock, remove the chuck cap from the top of the Multipro by screwing counterclockwise.
  7. Remove the black housing cap from the Multipro located directly below the chuck cap. Remove the black housing cap from the Multipro located directly below the chuck cap. Remove the black housing cap from the Multipro located directly below the chuck cap.
    • Remove the black housing cap from the Multipro located directly below the chuck cap.
  8. Pull the bottom side of the casing up to remove it. Pull the bottom side of the casing up to remove it. Pull the bottom side of the casing up to remove it.
    • Pull the bottom side of the casing up to remove it.
  9. Gently lift the motor shaft out of the Multipro. Gently lift the motor shaft out of the Multipro. Gently lift the motor shaft out of the Multipro.
    • Gently lift the motor shaft out of the Multipro.
  10. Pull the lock pin and its casing out of the other side of the Multipro case. Pull the lock pin and its casing out of the other side of the Multipro case. Pull the lock pin and its casing out of the other side of the Multipro case.
    • Pull the lock pin and its casing out of the other side of the Multipro case.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Matthew Satton
353 Reputation
2 Anleitungen geschrieben
A link to parts is always nice,
bari - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 19
Insgesamt: 1,180
