Zum Hauptinhalt wechseln
Dress Shirt Button Replacement
Was du brauchst
  1. Dress Shirt Button Replacement, Button: Schritt 1, Bild 1 von 2 Dress Shirt Button Replacement, Button: Schritt 1, Bild 2 von 2
    • Measure out two feet of thread and cut it.
  2. Dress Shirt Button Replacement: Schritt 2, Bild 1 von 3 Dress Shirt Button Replacement: Schritt 2, Bild 2 von 3 Dress Shirt Button Replacement: Schritt 2, Bild 3 von 3
    • The needle is sharp. Be careful when working.
    • Put the thread through the eye of the needle.
    • Pull the thread through so that both ends are even.
    • Tie both strings into a knot, closing the loop
  3. Dress Shirt Button Replacement: Schritt 3, Bild 1 von 2 Dress Shirt Button Replacement: Schritt 3, Bild 2 von 2
    • Begin sewing by putting the needle through the back of the fabric, out to the front, and through a hole in the button.
    • Make sure the button is facing the correct direction.
  4. Dress Shirt Button Replacement: Schritt 4, Bild 1 von 3 Dress Shirt Button Replacement: Schritt 4, Bild 2 von 3 Dress Shirt Button Replacement: Schritt 4, Bild 3 von 3
    • Put the needle through the hole diagonal and feed through to the back of the shirt
    • Repeat this process for the other diagonal.
    • Repeat the process of sewing through the diagonals multiple times.
  5. Dress Shirt Button Replacement: Schritt 5, Bild 1 von 1
    • When there is about 4 inches of thread yet, push the thread so that it is on the back side of the fabric.
    • Then push the needle back through making sure to not go through the button again.
  6. Dress Shirt Button Replacement: Schritt 6, Bild 1 von 3 Dress Shirt Button Replacement: Schritt 6, Bild 2 von 3 Dress Shirt Button Replacement: Schritt 6, Bild 3 von 3
    • Wrap the thread around the button 4-6 times.
  7. Dress Shirt Button Replacement: Schritt 7, Bild 1 von 3 Dress Shirt Button Replacement: Schritt 7, Bild 2 von 3 Dress Shirt Button Replacement: Schritt 7, Bild 3 von 3
    • Push the thread back through to the back side of the fabric.
    • Tie the knot off and cut.
Abschluss
Your shirt is now ready to be worn again.
Eine weitere Person hat diese Anleitung absolviert.
Jonathan Wong
198 Reputation
1 Anleitung geschrieben
Cal Poly, Team 28-4, Green Spring 2015 Mitglied von Cal Poly, Team 28-4, Green Spring 2015
CPSU-GREEN-S15S28G4
6 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 14
Letzte 30 Tage: 84
Insgesamt: 4,086
