Zum Hauptinhalt wechseln
Drill Master Heat Gun Motor Replacement
Was du brauchst
  1. Drill Master Heat Gun Motor Replacement, Motor: Schritt 1, Bild 1 von 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Motor Replacement: Schritt 2, Bild 1 von 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Motor Replacement: Schritt 3, Bild 1 von 3 Drill Master Heat Gun Motor Replacement: Schritt 3, Bild 2 von 3 Drill Master Heat Gun Motor Replacement: Schritt 3, Bild 3 von 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Motor Replacement: Schritt 4, Bild 1 von 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Motor Replacement: Schritt 5, Bild 1 von 1
    • Remove the metal casing and fan cover from the fan unit.
  6. Drill Master Heat Gun Motor Replacement: Schritt 6, Bild 1 von 1
    • Bend the metal prongs backward that connect the fan motor to the plastic cap.
    • Bending the brackets too far back can cause the brackets to break.
  7. Drill Master Heat Gun Motor Replacement: Schritt 7, Bild 1 von 1
    • Remove the plastic cap from the motor,
    • This will allow you to work only with the motor and fan.
  8. Drill Master Heat Gun Motor Replacement: Schritt 8, Bild 1 von 1
    • Remove the fan by pulling it from the motor rod.
  9. Drill Master Heat Gun Motor Replacement: Schritt 9, Bild 1 von 1
    • Remove the two 12mm screws from the plastic fan casing using PH#00
  10. Drill Master Heat Gun Motor Replacement: Schritt 10, Bild 1 von 1
    • Remove the plastic fan casing.
  11. Drill Master Heat Gun Motor Replacement: Schritt 11, Bild 1 von 1
    • Remove the metal casing from the motor and insert the new motor in its place.
    • You may have to tug a little.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mikayla Kim
523 Reputation
5 Anleitungen geschrieben
Ein Kommentar
Where can I find a new motor?
jstabler38 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 1,462
