Einleitung
This is a simple repair for your heat gun that can be accomplished by any level of DIY skill. Just be sure to have the listed tools and, of course, don't have your heat gun plugged in.
Was du brauchst
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Remove the two 12mm screws from the base of power cord using the PH#0 screwdriver.
