Zum Hauptinhalt wechseln
Drill Master Heat Gun Power Cord Replacement
Was du brauchst
  1. Drill Master Heat Gun Power Cord Replacement, Power Cord: Schritt 1, Bild 1 von 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Cord Replacement: Schritt 2, Bild 1 von 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Cord Replacement: Schritt 3, Bild 1 von 3 Drill Master Heat Gun Power Cord Replacement: Schritt 3, Bild 2 von 3 Drill Master Heat Gun Power Cord Replacement: Schritt 3, Bild 3 von 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Cord Replacement: Schritt 4, Bild 1 von 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Cord Replacement: Schritt 5, Bild 1 von 1
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Cord Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the power cord wiring from the wire connector.
  7. Drill Master Heat Gun Power Cord Replacement: Schritt 7, Bild 1 von 1
    • Remove the two 12mm screws from the base of power cord using the PH#0 screwdriver.
  8. Drill Master Heat Gun Power Cord Replacement: Schritt 8, Bild 1 von 1
    • Remove the power cord from the heat gun.
Abschluss
Mikayla Kim
523 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 656
