Einleitung
This requires soldering, so for a quick lesson or just a refresher, check out How to Solder and Desolder Connections.
Was du brauchst
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
