Zum Hauptinhalt wechseln
Drill Master Heat Gun Power Switch Replacement
Was du brauchst
  1. Drill Master Heat Gun Power Switch Replacement, Power Switch: Schritt 1, Bild 1 von 1
    • Be sure the heat gun is unplugged before starting this process.
    • Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
    • You will need a screwdriver extension.
  2. Drill Master Heat Gun Power Switch Replacement: Schritt 2, Bild 1 von 1
    • Remove the 8mm screw from underside of barrel using the PH#0 screwdriver.
    • Don't try to open the casing just yet.
  3. Drill Master Heat Gun Power Switch Replacement: Schritt 3, Bild 1 von 3 Drill Master Heat Gun Power Switch Replacement: Schritt 3, Bild 2 von 3 Drill Master Heat Gun Power Switch Replacement: Schritt 3, Bild 3 von 3
    • Remove the barrel casing on either end by twisting and pulling each side off.
  4. Drill Master Heat Gun Power Switch Replacement: Schritt 4, Bild 1 von 1
    • Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
  5. Drill Master Heat Gun Power Switch Replacement: Schritt 5, Bild 1 von 1
    • Loosen four screws on the wire connector using the flathead 2.5 screwdriver.
    • Screws do not come out of connector.
  6. Drill Master Heat Gun Power Switch Replacement: Schritt 6, Bild 1 von 1
    • Squeeze the tabs on either side of the power switch to remove from the casing.
  7. Drill Master Heat Gun Power Switch Replacement: Schritt 7, Bild 1 von 2 Drill Master Heat Gun Power Switch Replacement: Schritt 7, Bild 2 von 2
    • Remove the black, plastic wire protectors from the end of the power switch.
  8. Drill Master Heat Gun Power Switch Replacement: Schritt 8, Bild 1 von 1
    • Use soldering iron to remove the electrical wiring from the power switch. To replace the power switch, solder the new switch onto the wires.
    • Heating the soldering metal will allow you to pull off the electrical wiring.
    • For a brush-up on proper soldering, check out How to Solder and Desolder Connections.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Mikayla Kim
523 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 22
Insgesamt: 2,781
