Einleitung
This guide will provide you with the necessary steps in order to replace the driver side mirror of a 2002 Chevrolet Tahoe. A common occurence on this make is for the driver side mirror to fog over time and become unusable unless replaced. Many dealerships will try to persuade you into replacing the entire mirror module but that is unnecessary and costly.
Was du brauchst
Turn the mirror in towards the vehicle allowing access to the left side of the mirror.
Insert the screwdriver on the left side of the mirror and apply force to release.
Insert the screwdriver on the top of the mirror and apply force to release this section.
Repeat this step for the bottom portion along with the ride side of the mirror.
To reassemble your new mirror, follow these instructions in reverse order.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
