Einleitung
How to replace the Power Switch
Was du brauchst
To start getting the case off remove the front panel so it's out of the way.
Next remove the screws from the feet of the case with a phillips head screwdriver.
Unscrew the back face by removing the screw on the back sides, then slide top face apart from the others
3 weitere Personen haben diese Anleitung absolviert.
5 Kommentare zur Anleitung
Hello,
great info I found here, but where do I buy a replacement button for my Drobo in Europe?
Kind regards and thank you in advance,
Heinrich
Hi, where do I find a replacement power switch for my Drobo 5N? BTW, thanks for the great tutorial!
I took my Drobo apart and the printed numbers on the switch are R13-112. I ordered these on Amazon:
https://www.amazon.com/Twidec-Rocker-Tog...
I put it in, crossed my fingers, and BAM, worked like a charm. Hope that helps all the future DIY’ers.
Many thanks Rye. My Drobo 5C switch has been playing up for a while and your article gave me the courage to tackle the issue. A few dirfferences for the 5C (removing the back panel) but otherwise all tickety boo.
