Einleitung
This guide is to replace a damaged battery on the Motorola Droid XT 1080. It is important because your phone will not charge or turn on if the battery needs to be replaced.
Was du brauchst
Remove the SIM card tray from the side of the device using a plastic opening tool.
After properly removing the SIM card tray take your spudger and press it in between the plastic case and the frame of the device until you hear a snap.
Work your way from the top and the other side to confirm all the clips are disconnected.
Remove the five screws on top of the device with a T5 Torx.
Remove the single screw holding the camera with a T4 Torx.
Remove the two screws on the bottom of the device with a T5 Torx.
After the top and bottom screws are removed remove the top and bottom plastic pieces that were secured to the device.
Begin to gently pry up the battery from the frame with a plastic opening tool to release it from its adhesive securing.
Disconnect the LCD cable with a spudger from the motherboard by gently lifting up the two connectors.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
