Zum Hauptinhalt wechseln
Droid Ultra XT1080 Charging Port Replacement
Was du brauchst
  1. Droid Ultra XT1080 Charging Port  Replacement, Charging Port: Schritt 1, Bild 1 von 1
    • Remove SIM card tray from the device with a plastic opening tool.
  2. Droid Ultra XT1080 Charging Port  Replacement: Schritt 2, Bild 1 von 1
    • Once SIM card tray is removed press the spudger between the plastic case and the frame of the device until you hear a snap.
    • Work your away around the device until all the plastic clips are undone.
    • Be gentle with the plastic to make sure it doesn't break.
  3. Droid Ultra XT1080 Charging Port  Replacement: Schritt 3, Bild 1 von 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Charging Port  Replacement: Schritt 4, Bild 1 von 2 Droid Ultra XT1080 Charging Port  Replacement: Schritt 4, Bild 2 von 2
    • Once the screws are removed, use a plastic spudger and lift up the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Charging Port  Replacement: Schritt 5, Bild 1 von 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Charging Port  Replacement: Schritt 6, Bild 1 von 1
    • Gently pry the motherboard out of the frame of the device.
  7. Droid Ultra XT1080 Charging Port  Replacement: Schritt 7, Bild 1 von 2 Droid Ultra XT1080 Charging Port  Replacement: Schritt 7, Bild 2 von 2
    • Once the motherboard is free flip it over on its back so all the components are showing.
  8. Droid Ultra XT1080 Charging Port  Replacement: Schritt 8, Bild 1 von 1
    • To fully replace the charging port you need to desolder the port and solder a new one in.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
knoyes
785 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 824
