Zum Hauptinhalt wechseln
Einleitung
For this repair I replaced the LCD and Digitizer that comes with a frame. When ordering the part you should make sure it has the frame, because if you repair the front assembly without the frame, there will always be a slight lift in the screen. If you repair it without the frame it will still work, but you will run the risk of cracking the screen again due to that slight lift.
  1. Start by removing the Sim card tray, which also happens to be your volume button
    • Start by removing the Sim card tray, which also happens to be your volume button
  2. I personally used an iSesamo tool to unclip the tabs off the back housing, You can also use the Jimmy or some plastic prying tools.
    • I personally used an iSesamo tool to unclip the tabs off the back housing, You can also use the Jimmy or some plastic prying tools.
    • Do Not pry the back housing around the bottom of the screen. Pry on the left, right, and top. After that the back housing should slide off on the bottom.
  3. T5 Torx screws T3 Torx screw T5 Torx screws
    • T5 Torx screws
    • T3 Torx screw
    • T5 Torx screws
    • T5 Torx screws
    • When putting back together, do not tighten the screws too tight.
  4. T5 Torx screws
    • T5 Torx screws
  5. T5 Torx screws T5 Torx screws
    • T5 Torx screws
  6. With the iSesamo tool, or a prying tool, unclip the tabs on the left and right side of the phone. With the iSesamo tool, or a prying tool, unclip the tabs on the left and right side of the phone. With the iSesamo tool, or a prying tool, unclip the tabs on the left and right side of the phone.
    • With the iSesamo tool, or a prying tool, unclip the tabs on the left and right side of the phone.
  7. Using a Spudger  lift the motherboard from right to left. After lifting the motherboard from the frame remove the tape, and lift the black tab with your Spudger to remove the flex cable. When you place the new screen remember to replace the tape over the flex cable.
    • Using a Spudger lift the motherboard from right to left.
    • After lifting the motherboard from the frame remove the tape, and lift the black tab with your Spudger to remove the flex cable.
    • When you place the new screen remember to replace the tape over the flex cable.
    • Before putting the mother board on remember to transfer your ear speaker from the old frame to the new one.
  8. .... as long as you work your way backwards to put it back together.
    • .... as long as you work your way backwards to put it back together.
Abschluss
17 weitere Nutzer haben diese Anleitung absolviert.
Ricardo Martinez
739 Reputation
1 Anleitung geschrieben
I want to repair the scencor
Atihussan82 Hussain - Antwort
I want to repair the XT1080 sciencer
Repair screen on droid ultra XT 1080
churchy dezign - Antwort
I want to repair the camera on Droid turbo XT1080
King Bash - Antwort
My Android 1080 screen is frozen. How can I get my photos?
Madeline Rutledge - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 4,782
