Zum Hauptinhalt wechseln
Droid Ultra XT1080 Power Button Replacement
Was du brauchst
  1. Droid Ultra XT1080 Power Button Replacement, Power Button: Schritt 1, Bild 1 von 3 Droid Ultra XT1080 Power Button Replacement, Power Button: Schritt 1, Bild 2 von 3 Droid Ultra XT1080 Power Button Replacement, Power Button: Schritt 1, Bild 3 von 3
    • Gently remove the SIM card tray from the device using a spudger.
  2. Droid Ultra XT1080 Power Button Replacement: Schritt 2, Bild 1 von 1
    • After SIM card removal press the spudger between the plastic case and the frame until you hear a snap.
    • Work your way around the device until all the clips are released.
    • Be gentle while doing this so you don't crack or break the plastic.
  3. Droid Ultra XT1080 Power Button Replacement: Schritt 3, Bild 1 von 1
    • Remove the five screws on top of the device with a T5 Torx.
    • Remove the single screw holding the camera with a T4 Torx.
    • Remove the two screws on the bottom of the device with a T5 Torx.
  4. Droid Ultra XT1080 Power Button Replacement: Schritt 4, Bild 1 von 2 Droid Ultra XT1080 Power Button Replacement: Schritt 4, Bild 2 von 2
    • Once the screws are removed, use a nylon spudger and lift up on the two plastic pieces that were secured by the screws.
  5. Droid Ultra XT1080 Power Button Replacement: Schritt 5, Bild 1 von 1
    • Remove the four T5 Torx screws securing the motherboard.
  6. Droid Ultra XT1080 Power Button Replacement: Schritt 6, Bild 1 von 1
    • Gently pry the motherboard out of the frame using the plastic opening tool.
  7. Droid Ultra XT1080 Power Button Replacement: Schritt 7, Bild 1 von 2 Droid Ultra XT1080 Power Button Replacement: Schritt 7, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    $3.99
    • Once motherboard is removed you have gained access to the power button.
    • Gently, using a pair of angled tweezers pull on the power button to remove it.
Abschluss
knoyes
785 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S3-G8, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G8, Peak Fall 2018
UMASSD-PEAK-F18S3G8
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 357
