Zum Hauptinhalt wechseln
Drop-Front Desk Panel Repair
Was du brauchst
  1. Drop-Front Desk Panel Repair, Drop-Front Desk Panel: Schritt 1, Bild 1 von 3 Drop-Front Desk Panel Repair, Drop-Front Desk Panel: Schritt 1, Bild 2 von 3 Drop-Front Desk Panel Repair, Drop-Front Desk Panel: Schritt 1, Bild 3 von 3
    • Place the drop front panel on a firm and flat surface.
    • A firm surface minimizes the risk of the panel injuring one’s body or experiencing further damages.
  2. Drop-Front Desk Panel Repair: Schritt 2, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 2, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 2, Bild 3 von 3
    • Position the rectangular plate over the Phillips #5 wood screw holes (15mm) on the left width.
    • There are six Phillips #5 wooden screw holes in total (15mm). Four wooden screw holes (15mm) are on the left width of the panel and two other screw holes are on the width's side.
    • Repeat this step with the right width of the panel.
    • The rectangular plates that will later be fastened to the left and right width are connected to chains. The chains connect to another hinge piece that will later be connected to the main desk frame.
  3. Drop-Front Desk Panel Repair: Schritt 3, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 3, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 3, Bild 3 von 3
    • Use the Phillips #2 screwdriver to turn the six Phillips #5 wood screws (15 mm) and secure the rectangular plates to the left width of the panel.
    • Turn the screwdriver to the right to tighten the screws. Turn the screwdriver to the left to loosen the screws.
  4. Drop-Front Desk Panel Repair: Schritt 4, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 4, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 4, Bild 3 von 3
    • Position the hemispherical plates over the left hemispherical hole on the length of the panel.
    • Repeat this step with the right length of the panel.
    • A hemisphere is the half of a circle.
    • Use the Phillips #2 screwdriver to turn the three #5 wood screws (15mm) and tighten the hemispherical plates along the length of the drop-front panel.
  5. Drop-Front Desk Panel Repair: Schritt 5, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 5, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 5, Bild 3 von 3
    • Prevent dropping the drop-front panel by carrying the panel with each hand grasping both sides of the panel's width.
    • Carry the panel from the flat surface to the main desk frame.
  6. Drop-Front Desk Panel Repair: Schritt 6, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 6, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 6, Bild 3 von 3
    • Connect the panel to the bottom edge of the main desk frame.
  7. Drop-Front Desk Panel Repair: Schritt 7, Bild 1 von 2 Drop-Front Desk Panel Repair: Schritt 7, Bild 2 von 2
    • Position the panel's hemispherical plates over the hemispherical holes on the left and right side of the main desk frame.
  8. Drop-Front Desk Panel Repair: Schritt 8, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 8, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 8, Bild 3 von 3
    • Have one person hold the drop-front panel in place and another person screw the hinges in place.
    • Use the Phillips #2 screwdriver to turn the three Phillips #5 wood screws (15mm) and tighten the hemispherical hinges on the main desk frame.
  9. Drop-Front Desk Panel Repair: Schritt 9, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 9, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 9, Bild 3 von 3
    • Position the second half of the rectangular plate over the four wood screw holes (15mm) on the left side of the inner desk frame.
    • Repeat this step with the right side of the inner desk frame.
    • Use the Phillips #2 screwdriver to screw the four #5 wood screws (15mm) and tighten the rectangular plate.
  10. Drop-Front Desk Panel Repair: Schritt 10, Bild 1 von 3 Drop-Front Desk Panel Repair: Schritt 10, Bild 2 von 3 Drop-Front Desk Panel Repair: Schritt 10, Bild 3 von 3
    • Test the connection between the main desk frame and the drop-front panel by raising the panel towards the inner desk frame and away from it.
    • If the connection is unsteady or makes noise as you raise and lower the panel, tighten all the screws on the panel and the main desk frame.
Abschluss
To disassemble your device, follow these instructions in reverse order.
Kiarra
181 Reputation
1 Anleitung geschrieben
USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019 Mitglied von USF Sarasota-Manatee, Team S1-G1, Stewart Spring 2019
USFSM-STEWART-S19S1G1
18 Mitglieder
27 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 15
Letzte 30 Tage: 47
Insgesamt: 3,354
