Zum Hauptinhalt wechseln
DualSense Controller V5 Middle Trim Replacement
Was du brauchst
  1. DualSense Controller V5 Middle Trim Replacement, Unclip the right end of the middle trim: Schritt 1, Bild 1 von 2 DualSense Controller V5 Middle Trim Replacement, Unclip the right end of the middle trim: Schritt 1, Bild 2 von 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: Schritt 2, Bild 1 von 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: Schritt 2, Bild 2 von 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: Schritt 2, Bild 3 von 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller V5 Middle Trim Replacement, Unclip the left end of the middle trim: Schritt 3, Bild 1 von 2 DualSense Controller V5 Middle Trim Replacement, Unclip the left end of the middle trim: Schritt 3, Bild 2 von 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: Schritt 4, Bild 1 von 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: Schritt 4, Bild 2 von 3 DualSense Controller V5 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: Schritt 4, Bild 3 von 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: Schritt 5, Bild 1 von 3 DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: Schritt 5, Bild 2 von 3 DualSense Controller V5 Middle Trim Replacement, Remove the middle trim: Schritt 5, Bild 3 von 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
Abschluss
Spencer Day
119.439 Reputation
838 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
119 Mitglieder
21.959 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 34
Insgesamt: 76
