Einleitung
Often, through expected usage, an analog stick may become dislodged or misaligned on the DualShock 2 Wireless controller. This guide will show how to remove the faulty stick and realign it.
Was du brauchst
Remove the six 7.8 mm anchoring screws from the back casing of the controller using a Phillips #0 screwdriver.
Pull apart the outer casing by hand, or by using a plastic opening tool, from the bottom of the controller.
Remove the two 6.1 mm screws holding the internal analog stick board and the front of the controller together.
Lift the analog stick board away from the front of the controller.
Remove the detached or loose analog stick for realignment.
Realign the analog stick by pushing the removed stick back into its chassis with focus on pushing it in at the new, desired resting angle. You should feel or hear a small click if done correctly.
16 weitere Personen haben diese Anleitung absolviert.
