Zum Hauptinhalt wechseln
DualShock 3 Trigger Buttons Replacement
Was du brauchst
  1. DualShock 3 Trigger Buttons Replacement, Rear Cover: Schritt 1, Bild 1 von 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
  2. DualShock 3 Trigger Buttons Replacement: Schritt 2, Bild 1 von 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
  3. DualShock 3 Trigger Buttons Replacement: Schritt 3, Bild 1 von 2 DualShock 3 Trigger Buttons Replacement: Schritt 3, Bild 2 von 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
  4. DualShock 3 Trigger Buttons Replacement, Trigger Buttons: Schritt 4, Bild 1 von 1
    • While holding the black plastic trigger retainer with one hand, pull the #2 trigger off of its axle.
  5. DualShock 3 Trigger Buttons Replacement: Schritt 5, Bild 1 von 2 DualShock 3 Trigger Buttons Replacement: Schritt 5, Bild 2 von 2
    • When reinstalling the #2 trigger, be sure the spring is positioned as shown before popping the axle back into place.
  6. DualShock 3 Trigger Buttons Replacement: Schritt 6, Bild 1 von 2 DualShock 3 Trigger Buttons Replacement: Schritt 6, Bild 2 von 2
    • Pull the black plastic trigger retainer slightly away from the front cover.
    • Pull the #1 button out of the front cover.
  7. DualShock 3 Trigger Buttons Replacement: Schritt 7, Bild 1 von 2 DualShock 3 Trigger Buttons Replacement: Schritt 7, Bild 2 von 2
    • Before sliding the trigger button retainer back into the rails molded into the front cover, be sure that the cylindrical post attached to the #1 button is sitting flat on the green rubber electronic switch cover. Failure to do so may lead to problems with fit during reassembly, and may cause the controller to not recognize inputs from the #1 button during operation.
    • The trigger button assembly is properly installed when the lip on the trigger button retainer sits flat against the motherboard.
Abschluss
69 weitere Nutzer:innen haben diese Anleitung absolviert.
8 Kommentare
Might want to add that there's a small catch/tab in the middle of the bottom of the controller that needs to be released when taking apart the covers.
This worked great, and also works on normal Sixaxis controllers. I used this to swap the broken spring from the L2 button on my DS3 for a good spring from my Sixaxis. Works like new now.
Will Foss - Antwort
The little green eletronic ribben where is it supposed to go?
dmall - Antwort
The #00 screwdriver is working better
Leopold287 - Antwort
Did you replace button 2 rod with plastic replacement part or use original rod piece when fixing button 2
Sidney Klemkosky - Antwort
Is there a way I can buy trigger retainers?
CynicalSheep - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 22
Letzte 7 Tage: 145
Letzte 30 Tage: 779
Insgesamt: 113,593
