Was du brauchst
Unscrew the four 6.5mm screws, using a Phillips-Head screwdriver.
Pry the two halves of the shell apart using a plastic opening tool.
Pull the ribbon cable out of the motherboard port to fully separate the two halves, using a pair of tweezers.
Unplug the black and red wires from the power port located on the motherboard.
Remove the old battery from the controller.
Remove the 6.43mm screw connecting the motherboard to the inner workings of the controller, using a Phillips-Head screwdriver.
19 weitere Nutzer:innen haben diese Anleitung absolviert.
