Zum Hauptinhalt wechseln
DualShock 4 CHU-ZCT2U Joystick Cover Replacement
Was du brauchst
  1. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the rear panel screws: Schritt 1, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the rear panel screws: Schritt 1, Bild 2 von 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Separate the rear panel: Schritt 2, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Separate the rear panel: Schritt 2, Bild 2 von 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Release the plastic clips: Schritt 3, Bild 1 von 3 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Release the plastic clips: Schritt 3, Bild 2 von 3 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Release the plastic clips: Schritt 3, Bild 3 von 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the rear panel: Schritt 4, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the rear panel: Schritt 4, Bild 2 von 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 5, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 5, Bild 2 von 2
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the battery: Schritt 6, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the battery: Schritt 6, Bild 2 von 2
    • Use a pair of tweezers to pull the battery's power connector straight up from the motherboard.
  7. DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 7, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 7, Bild 2 von 2
    • Remove the battery.
  8. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the motherboard: Schritt 8, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the motherboard: Schritt 8, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 6.4 mm-long screw securing the battery bracket.
  9. DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 9, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 9, Bild 2 von 2
    • Remove the battery bracket.
  10. DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 10, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 10, Bild 2 von 2
    • Use a pair of tweezers to disconnect the touch panel ribbon cable.
    • Pull the ribbon cable directly away from its connector on the motherboard by the blue pull tab, not by the cable itself.
  11. DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 11, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 11, Bild 2 von 2
    • Separate the motherboard and midframe assembly from the front panel.
  12. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the joystick covers: Schritt 12, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Remove the joystick covers: Schritt 12, Bild 2 von 2
    • Pull the right joystick cover straight off the joystick module to remove it.
  13. DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 13, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement: Schritt 13, Bild 2 von 2
    • Pull the left joystick cover straight off the joystick module to remove it.
  14. DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Reassembly tip: Schritt 14, Bild 1 von 2 DualShock 4 CHU-ZCT2U Joystick Cover Replacement, Reassembly tip: Schritt 14, Bild 2 von 2
    • During reassembly, ensure the new joystick covers properly align with the shafts on the joystick modules before pressing them into place.
Abschluss
26 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Omiotek
58.178 Reputation
288 Anleitungen geschrieben
Guide Team Mitglied von Guide Team
Community
10 Mitglieder
9.784 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 11
Letzten 7 Tage: 114
Letzten 30 Tage: 508
Insgesamt: 11,261
