Zum Hauptinhalt wechseln
DualShock 4 CHU-ZCT2U Rear Panel Replacement
Was du brauchst
  1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: Schritt 1, Bild 1 von 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: Schritt 1, Bild 2 von 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: Schritt 2, Bild 1 von 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: Schritt 2, Bild 2 von 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: Schritt 3, Bild 1 von 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: Schritt 3, Bild 2 von 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: Schritt 3, Bild 3 von 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: Schritt 4, Bild 1 von 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: Schritt 4, Bild 2 von 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Rear Panel Replacement: Schritt 5, Bild 1 von 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Omiotek
73.594 Reputation
288 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 78
Insgesamt: 2,703
