Zum Hauptinhalt wechseln
DualShock 4 CUH-ZCT2U D-pad Gasket Replacement
Was du brauchst
  1. DualShock 4 CUH-ZCT2U D-pad Gasket Replacement, D-pad Gasket: Schritt 1, Bild 1 von 2 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement, D-pad Gasket: Schritt 1, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the four 6.0 mm-long screws on the back of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 2, Bild 1 von 2 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 2, Bild 2 von 2
    • Four fragile plastic clips hold the front and back case together. You can see their locations more clearly in this guide.
    • If you break these clips, the controller will still work.
    • Insert the tip of an opening tool or spudger into the seam of the device and gently release the clips around the perimeter of the controller to separate the front and back sections.
    Frag FixBot
  3. DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 3, Bild 1 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 3, Bild 2 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 3, Bild 3 von 3
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with your fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • Do not remove the entire socket from the motherboard, just the ribbon cable. The blue part of the cable should be visible if done correctly.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
    Frag FixBot
  4. DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 4, Bild 1 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 4, Bild 2 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 4, Bild 3 von 3
    • Use a pair of tweezers or your fingers to pull the battery's power connector straight up from the motherboard.
    Frag FixBot
  5. DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 5, Bild 1 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 5, Bild 2 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 5, Bild 3 von 3
    • Use a spudger to disconnect the red cable from the motherboard under the black plastic the battery was lying on.
    • Carefully pull apart the front of the controller (the part with the silicon Dpad visible) from the back half.
    • Tweezers were used in the image. However, using metal tools on the internals of your controller can damage them so it is best to avoid using them for prying.
    Frag FixBot
  6. DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 6, Bild 1 von 2 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 6, Bild 2 von 2
    • Pull off the old silicone pads.
    • Place the new silicone rubber pads on top of the four arrow keys with the flat side up.
    • The orientation does not matter.
    Frag FixBot
  7. DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 7, Bild 1 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 7, Bild 2 von 3 DualShock 4 CUH-ZCT2U D-pad Gasket Replacement: Schritt 7, Bild 3 von 3
    • To reassemble, follow these instructions in reverse order.
    Frag FixBot
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
York University, Team 2-30, O'Regan Winter 2024 Mitglied von York University, Team 2-30, O'Regan Winter 2024
YORK-O'REGAN-W24S2G30
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 156
Insgesamt: 3,498
