Zum Hauptinhalt wechseln
Durofix RV332 Motor Replacement
Was du brauchst
  1. Durofix RV332 Motor Replacement, Screwdriver Motor: Schritt 1, Bild 1 von 1
    • Remove the six 13 mm case screws with philips #0 screwdriver.
  2. Durofix RV332 Motor Replacement: Schritt 2, Bild 1 von 2 Durofix RV332 Motor Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic separating tool to separate the casing halves of the cordless screwdriver.
  3. Durofix RV332 Motor Replacement: Schritt 3, Bild 1 von 2 Durofix RV332 Motor Replacement: Schritt 3, Bild 2 von 2
    • Once the screwdriver casings have been separated, remove the printed circuit board, battery, LED, and motor assembly from the screwdriver casing.
    • Using the wire cutters, cut the black and red motor wires where they connect to the motor.
  4. Durofix RV332 Motor Replacement: Schritt 4, Bild 1 von 1
    • Strip the ends of the wires clean with the wire cutters. Strip the wire insulation 1/4" from the end of the wire.
  5. Durofix RV332 Motor Replacement: Schritt 5, Bild 1 von 3 Durofix RV332 Motor Replacement: Schritt 5, Bild 2 von 3 Durofix RV332 Motor Replacement: Schritt 5, Bild 3 von 3
    • Ensure the new motor terminals are clean before soldering.
    • Solder the red wire to the positive motor terminal, designated by a plus sign with a red circle around it.
    • Solder the black wire to the other terminal of the motor.
    • Allow the newly soldered assembly to cool before continuing.
  6. Durofix RV332 Motor Replacement: Schritt 6, Bild 1 von 1
    • Once the motor has cooled, replace the motor, printed circuit board, LED, and battery inside the screwdriver casing.
Abschluss
Tyler Vincent
464 Reputation
4 Anleitungen geschrieben
Michigan Tech, Team 5-5, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-5, Lauer Spring 2014
MTU-LAUER-S14S5G5
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Too late finding this (although self-explanatory). I was wondering when I tried this - WHERE does one find the spare component motor to replace? I searched the internet, but for something so specific, I just couldn't locate the right channels. For future reference, is there a typical store of small motors, etc... to locate these things?
Arkadiusz - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 1
Letzten 7 Tage: 1
Letzten 30 Tage: 7
Insgesamt: 704
