Einleitung
This guide leads you through the process of opening up the LabelManager and changing the keyboard. Keep in mind that the device has loose parts. Be careful and keep track of all parts.
Was du brauchst
Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
