Zum Hauptinhalt wechseln
Dymo LabelManager 280 Screen Replacement
Was du brauchst
  1. Dymo LabelManager 280 Screen Replacement, Rear Case: Schritt 1, Bild 1 von 2 Dymo LabelManager 280 Screen Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Remove battery.
    • Remove the label cassette.
  2. Dymo LabelManager 280 Screen Replacement: Schritt 2, Bild 1 von 2 Dymo LabelManager 280 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the 6 screws in the indicated places. These particular screws are 2mm x 8mm Phillips #0 head
  3. Dymo LabelManager 280 Screen Replacement: Schritt 3, Bild 1 von 2 Dymo LabelManager 280 Screen Replacement: Schritt 3, Bild 2 von 2
    • Use the spudger to take apart the device by insterting it as shown in the picture and twisting it. This should be done all around the device to ensure the two parts split correctly.
    • The keys/buttons highlighted in the second picture fall out easily so be careful. Keep device faced down in order to keep them from falling.
  4. Dymo LabelManager 280 Screen Replacement, Screen: Schritt 4, Bild 1 von 1
    • Further remove the 2 screws (1.2mm X 4mm Phillips #0 head).
  5. Dymo LabelManager 280 Screen Replacement: Schritt 5, Bild 1 von 2 Dymo LabelManager 280 Screen Replacement: Schritt 5, Bild 2 von 2
    • Detach the ribbon cable.
  6. Dymo LabelManager 280 Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the screen.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Steven Nguyen
431 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 6-5, Eyestone Spring 2016 Mitglied von USF Tampa, Team 6-5, Eyestone Spring 2016
USFT-EYESTONE-S16S6G5
3 Mitglieder
1 Kommentar zur Anleitung
Hi, thak you for the tutorial, it seems pretty simple. Do you know where to find the LCD screen, or whats the specs, maybe I can find it at AliExpress.
Jacques Maltais - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 8
Letzte 30 Tage: 34
Insgesamt: 3,963
