Einleitung
Can't watch your favorite movie? Replacing the optical disc drive may help.
Was du brauchst
Before removing the screen, be sure to turn off and unplug your device.
Flip your device over, so the bottom is facing up.
Remove the back cover held by thirteen 3.175 mm head, 9.525 mm length pan-head Phillips screws.
Use a plastic opening tool to pop open the back case.
Do not separate the back cover completely, wires are still connected to both sides.
Hold the back cover upright and remove the black tape connecting the wire group to the cover.
Remove the bottom two pieces of tape connecting wires to the CD tray.
Locate the small circuit board on the underside of the buttons.
Remove the circuit board for the buttons, held by six 3.175 mm head, 4.762 mm length flat-head Phillips screws.
Remove the three wire connections that are located on the main (largest) circuit board.
The connection can be gently removed with a plastic opening tool or with your fingers by pinching the ends and pulling.
Remove the optical disc drive by lifting it off the three pegs on the bottom case.
Now that the optical drive is removed from the case, flip it over and locate the ribbon cable.
Gently pull out the two sides of the brown tab underneath the ribbon cable, see images for detail.
Once both sides of the tab are out, it should require no force to pull the ribbon cable out of the connection on the optical drive.
Now the optical drive should be removed and still connected to the circuit board which was underneath the buttons.
Desolder the optical drive wires from the circuit board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
